I decided to remove the 350 so I can detail under the hood. The engine bay is empty, just the short block sitting there attached to the TH400. The car ia sitting level on 4 jack stands. This is what I plan - if there is a better/easier way, PLEASE tell me..
1. loosen the engine mount 'thru' bolts
2. remove torgue converter bolts
3. remove engine to bell housing bolts, leave 1 lower
4. raise engine enough to remove 'thru' bolts
5. contine raising engine to clear egine mounts
6. support transmission and remove the last bell housing bolt
7. seperate engine from transmission
Some questions - Can I leave the starter attached ? and will a engine hoist 'reach' from the front or will I have lift from the side ?
Jim
Jim
