'66 ENGINE SUFFIX "HP" - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    Although I posted this same question some time back, and appreciate the reply, I am reposting it. The small, covettte black book and the Noland Adams book both list the "HP" suffix for a '66 small block as 350HP with N40. I've been told that "HT" would be correct for 350HP, manual transmission. Since I'm looking for a '66 350HP, manual with factory installed power steering I wanted to check one more time to make sure the correct code is "HT", whether N40 was installed or not. I thought it strange that the same error be made in two different books. (I see in the '67 judging manual that "HT" is correct, but I don't have the '66 judging manual to refer to).
  • Mike M.
    • May 31, 1974
    • 8365
    Re: '66 ENGINE SUFFIX "HP"
    66 judging manual, spring 98, lists HT as suffix for a 350 hp 4 speed. mike
    • Dan A.
      • May 31, 1974
      • 1074
      I think the HP indicates L79 with C60 (air conditioning) and N40 (power steering). Differnt bunch of belts and pulleys than just L79.
      Yep that's what it says in my old second edition (Fall 1993) 1966 Judging Manual shows this as does Colvin's book.
      Dan
      • Rob A.
        • December 1, 1991
        • 2126
        Thanks, guess it's just a mistake in the books I mentioned.
        • Rob A.
          • December 1, 1991
          • 2126
          Thanks...
          • Randy S.
            • January 1, 2003
            • 586
            From 66 JG 2nd edition
            HT is L79 4 speed no options
            HP is L79 4 speed options of Air Cond Power steering
            Paragon cat for valve cover decals says
            HT as L79 and 4 speed
            HP as L79 4 speed AC,PS
            MF Dobbins fact Book 9th edition
            Under 327 1966 Engine series numbers and suffix chart
            HT Special High performance
            HP power steering
            Hope this helps
            Randy
            • Rob A.
              • December 1, 1991
              • 2126
              Thanks...
              • Henry J.
                • November 1, 1999
                • 457
                Rob, my April 66-built L79 is optioned with FACTORY power steering and brakes and NO air conditioning. It is a low mileage, very original car. The engine suffix code is HT.
                • Rob A.
                  • December 1, 1991
                  • 2126
                  That about says it all....Thanks...
