I was surprised to see a trashed pilot bearing sitting at the end of the crank in my 63 340 car. I put in a new LUK clutch 3 years ago and assumed I used the bushing supplied. Apparently, I popped in the pilot bearing at that time. It was installed properly and the engine/trans hookup occurred while the engine was out of the car and it went in very smoothly. It sure looks like the
GM 14061685 bearing I just picked up yesterday. The casing of the bearing is all that is left - the rest is a tangled mess behind the bearing. The input shaft on the 4 speed has a small groove in it from spinning on the trashed bearing. Is a bearing puller needed to remove or will the grease/ water trick work? Can the tranny be poorly aligned resulting in this problem? I cannot find any archive covering a failed bearing - it sounded like they are bullet proof. Thanks
