TI dist, part #...ATTN Joe Lucia - NCRS Discussion Boards
  • bruce11495
    Hi Joe....Do you have a listing for this part number 1112039, 1F7 date code? No tach drive hookup? Appears to be an aluminium housing...Pontiac???
    Thx Bruce
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: TI dist, part #...ATTN Joe Lucia
    my list shows 1112039 as 1971 307 cu in 140 hp camaro.
      Bruce----
      I've got it about the same as clem; the 1112039 was used for 1971 Chevelles, Camaros, and Novas with 200 hp 307 with automatic transmission. It's possible that it was used for some other applications, too.
      • bruce11495
        Thanks Joe and Clem. I thought it might have been from a Poncho, but I was wrong. Does it seem unusual for TI to be used on this model? Would the pieces in the distributor, ( pole piece, mag pick-up) be interchangeable with the Vette stuff?
        • Clem Z.
          • January 1, 2006
          • 9427
          it may be a conversion because you could buy the internal pieces and change over a point distributor to TI because i have done that. that number is a point distributor because in the specs they give the points gap.
            Bruce-----
            This distributor was not originally built as a TI. It was an aluminum housing, single point type distributor. If it has TI, then it's definitely a conversion. The parts used, if they're Delco parts, should work with a Corvette cast iron distributor housing. However, the main shaft will not have a tach drive gear.
