1963 Original Key Descripition - NCRS Discussion Boards
  • Irby G.
    • November 1, 2001
    • 267
    To All,
    Could somone please describe the original '63 ignition key. I have a chance to purchase a NOS set of blank keys. The seller decribes the keys as:
    ("GM YOUR KEY TO GREATER VALUE" on one side and "Briggs & Stratton Corporation Milwaukee Wis U.S.A." on the other.The key blanks have the "Knock Out" removed. The Ignition key is Hex shaped) Does this sound correct? I also understand there was no glove box key and the ignition key operated the spare lock also.
    Thanks in advance.
    Keys
  • Alan Drake
    Re: 1963 Original Key Descripition
    Check out the HOME page here - there is a survey going on now!
    My 1964 key is hex, on one side has GM in lower center with "YOUR KEY TO GREATER VALUE" on outside edge while the other side has "BRIGGS & STRATTON CORPORATION" and "MILWAUKEE WIS USA" along edges with Briggs logo in lower center.
    • Harry Sadlock
      Re: 1963 Original Key Description
      Irby, Hopefully a member will post pictures of both sides of an original 63 key. Also, I sent you an email.
      Harry
      38513
      • Robert C.
        • December 1, 1993
        • 1153
        Re:They look just like my 65 keys *NM*
        • Irby G.
          • November 1, 2001
          • 267
          Thanks for the replies guys. That Home page did the trick. Aloha
          • Harry Sadlock
            Irby, I responded to your email and that email address also came back as invalid.
            Harry
