C2; Holley Carb - Screw Staking Tool
  • Gerard F.
    • July 1, 2004
    • 3803
    #1
    Is there a special tool used to stake the small brass screws on a carburetor choke plate or throttle plate, so that the screw can never loosen or come out.
    Jerry Fuccillo
  • Wayne W.
    • May 1, 1982
    • 3605
    Re: C2; Holley Carb - Screw Staking Tool
    Yea, Its called a cold chisel.
    • Gerard F.
      • July 1, 2004
      • 3803
      Wayne,
      I figured it was something simple, but is there a trick to staking the two screws on a Holley choke plate without bending the choke plate shaft? I guess one would have to come up from the bottom with a long chisel.
      I also thought about using a pair of needle nose vise grips and work from the top, but I think I'd also screw up the head of the screw.
      Jerry Fuccillo
      #42179
      Jerry Fuccillo
      • Clem Z.
        • January 1, 2006
        • 9427
        i just use red loc tite but
        do not get any on the choke shaft were it goes tru the carb body or the choke will not move. just put a little on the screws before installing them
        • Wayne W.
          • May 1, 1982
          • 3605
          Re: i just use red loc tite but
          I am sure they had a fixture at the factory. The screws are brass so it will not take much force. Or as mentioned use locktite.
