Removing torque converter/drive plate bolts - NCRS Discussion Boards
  • Jim Callan
    I'm trying to remove the engine from my '71 C3 with 350/Th400. I have been able to stop the crank from turning by allowing the breaker bar to contact the frame on p/side, but I can't get the bolts to break loose. I'm AFRAID to using too much torque will snap the bolt or strip it. Do these bolts use 'left hand' threads ?
  • Jim T.
    • March 1, 1993
    • 5351
    Re: Removing torque converter/drive plate bolts
    Jim the torque converter bolts are removed from the flex plate counter-clock-wise.
