C2 Carb date question - NCRS Discussion Boards
  • John Perkins
    I have a 65 L76 with a 1970 replacement Holley. All of the other parts are original and correctly dated. The car has a build date of K23 (June 23) and the engine has a casting date of E55 or May 5 and the engine assembly date is May 18. What are the acceptable date codes for a Holley 2818 for this car? Thanks
  • Mike M.
    • May 31, 1974
    • 8365
    Re: C2 Carb date question
    april or early may would be ideal. mike
    • Robert C.
      • December 1, 1993
      • 1153
      The NCRS gives you up to 6mo's prior to the build date. Mike mentioned the IDEAL dates.
      • John Perkins
        Bob, thanks for your response. There is a 2818 that I can get my hands on with a date code of 554 which if I am not mistaken is May 1965 on the fourth week. Is that acceptable?
          Since your car is a June build, the May dated carb is WELL within BOTH the 0-6 month judging standard as well as Mike's 1-2 month prior suggestion....
          • Gerard F.
            • June 30, 2004
            • 3803
            What would be the point loss for
            a perfect original carb except for a replacement date code. I've got many hours into a replacement 3810 for a 67.
            Jerry Fuccillo
            #42179
            Jerry Fuccillo
            • Robert C.
              • December 1, 1993
              • 1153
              Re:Date= 20% of the score *NM*
