I want to replace my weak valve springs on my 1966 327/350hp Vette. I think the original part number of the spring is: 3735381. What is the specs. of the original spring? (Lift, open, and close pressure) I see .550 lift and .600 lift springs, but I just need the stock size.
My question is, What type of spring should I put into the car? Everything is still stock on the car. (Cam, valves, rockers bolts are still the "press" in fit type.) Is there any aftermarket springs that will work better? (without missing up my cam or rocker towers)? Thanks
