C2 pinion seal - NCRS Discussion Boards
C2 pinion seal
  • Dave Allert
    C2 pinion seal
    I am starting to replace the pinion seal on my 65 and ran into a problem. When I go to remove the front bolt on the Carrier Bracket, it hits the floor pan before it is all the way out. The book says that to remove the rear bolt you need to drill a hole in the floor pan, but I would like to avoid doing this if possible. Duke told me on his 63 there are two small bolts on the front of the bracket, but my 65 has one long bolt. (correct according to the AIM)
    Help please!
    Dave
