C2:67/300HP Holley- Staged Power Valve? - NCRS Discussion Boards
  • Gerard F.
    • June 30, 2004
    • 3803
    I'm getting ready to put my replacement 3810 back together after replating the parts. The carb kit I ordered for a 3810, came with a staged power valve, which is different from the original single stage power valve in the 4743 block.
    What difference in performance or ecomony would I get with the staged valve vs the single stage. As a geezer, I'm interested in economy in highway driving, but I still, on occasion, like to pass a Honda at 90.
    Clem, are you there.
    Jerry Fuccillo
    #42179
    Jerry Fuccillo
  • Clem Z.
    • January 1, 2006
    • 9427
    to quote the holley catalog
    two stage PV ARE NOT RECOMMENDED for performance applications
    • Gerard F.
      • June 30, 2004
      • 3803
      One more question
      Clem,
      I checked my Holley Carb Handbook and chucked the staged valve and put in a #65 power valve. I guess with the staged valve, it would run lean and hot, if I passed a Honda at 90.
      But here's the other question- Check ball in the Secondary Thottle diaphragm or or not? The Handbook (for all and newer Holleys) indicates a check ball in the diaphragm housing and the kit includes one. The Holley Illustrated Parts and Specs Manual shows one in the diagram, but doesn't list a part number in the variable parts and specifications section for a 3810A. My 67 GM overhaul manual has no mention of a check ball in the vacuum secondary diaphragm housing.
      So what gives. Was the check ball some later addition or modification?
      Jerry Fuccillo
      #42179
      Jerry Fuccillo
      • Clem Z.
        • January 1, 2006
        • 9427
        Re: One more question
        that i can not tell you for sure. most all of holleys aftermarket vacuum secondary performance carb come without the ball check valve. i would try it without it and see if you get a bog when the secondaries open and if you do and you have the correct spring install the ball.
        • Wayne K.
          • December 1, 1999
          • 1030
          Re: C2:67/300HP Holley- Staged Power Valve?
          Jerry,
          3810, no check ball. Also to check if secondaries not only open but how far they open make a telltale out of a twistem. Wrap the twistem equal length around the drivers side of the secondary throttle shaft twisting it full length so that it is tight on the shaft but will slip as the shaft turns. Lay the twisted end on the throttle body (pointed to front of car). Manually open the primaries all the way and while holding them open manually open the secondaries.
          You will see how the telltale works. If the secondaries open all the way the telltale will be straight up when the throttle shaft returns to the closed position. If not opening fully it will be somewhere between straight up and the starting position.
          Wayne
          • Clem Z.
            • January 1, 2006
            • 9427
            there is a easier way to tell wide open throttle
            just put a small dab of grease on the throttle body where the secondary throttle linkage stop hits at WOT,make a pass and see if the grease has a mark in it. if not you have not reached WOT on the secondary and you need a lighter spring
            • Wayne K.
              • December 1, 1999
              • 1030
              Re: there is a easier way to tell wide open thrott
              Clem,
              Your method works too but I came up with the twistem idea as it was easy to implement and told me how far and if at all the secondaries were opening. In my case I was only getting 1/2 benefit from the secondaries so I did change the spring as you have suggested. Besides, the little women made me clean my ears that day so I was low on grease.
              • Gerard F.
                • June 30, 2004
                • 3803
                Thanks for the advice
                Is there a color code to the spring. The book said purple, but I think they sent me green. I 'll have to take it apart again to check.
                Also is there a way to bench test for flow and leaks on a holley.
                Jerry Fuccillo
                #42179
                Jerry Fuccillo
                • Wayne K.
                  • December 1, 1999
                  • 1030
                  Re: Thanks for the advice
                  Jerry,
                  The springs are color coded. The 3810 should have a purple one. I had to go to a lighter spring to get full opening on my L-79. I don't remember the color code range.
                  Wayne
                  • Clem Z.
                    • January 1, 2006
                    • 9427
                    the holley catalog lists the RPM opening
                    for the different color springs with different engine size
