Hi. I'm trying to get my 67 column apart (non-tele) to change the turn signal switch and detail it. I pulled the large nut and washer off, but there appears to be a very thin nut right on top of the hub. I haven't been able to get this off because it is so thin and the socket slip right off. Is this supposed to come off or it is part of the hub? Do I use a puller to get the hub off? Any help is appreciated!
thanks, Brandon
thanks, Brandon
