'65 396 Holley 3124 - NCRS Discussion Boards
'65 396 Holley 3124
  • Dan 80
    '65 396 Holley 3124
    Does anyone know how the fuel bowls on the service replacement Holley LIST #3124 differ from the originals? And any other differences?
  • George Daina
    What I would do....
    go to a flea market, pick up a junk Holley that has the bowls and screws that you need. Make sure the needle & seat threads are there. Scap carps usually run around 15-20. Few years ago I picked up a 3418, complete, for $30.00, could not believe it. There are lot of rare Holleys that the sellers don't know the application, except the 3x2 carbs.
    The difference between new & old bowls....don't know, but the fastners on new Holleys are no longer slotted for a straight screwdriver. I don't know if the socket is metric or not.
    • Philip C.
      • December 1, 1984
      • 1117
      Re: '65 396 Holley 3124
      I believe the fuel inlet nuts are acorn shaped on orig and not on service ones. Hope this helps Phil #8063
      • Jerry
        Re: What I would do....
        Georges advice is excellent as usual , I might add to check the fuel inlet threads also as they are a very commonly stripped portion of the fuel bowl, ( people attempting to stop leaks ).
        Jerry
          Yes, I have '69 date coded service replacement 3124 on my 396 that I proudly take originality deduction(s) for because it's a FINE example of a 'correct' GM service part from the era (rubber inspector's stamp still visible on air horn and other tiny marks that are NOT mentioned in our Judging Guides).
          Service bowls have wider raise in casting leading to fuel line connections. They were designed (like '66 and later bowls) to accommodate internal gas filter vs. GS-416 factory original, single, external, in-line filter.
          Original 3124 bowls are much more narrow (flat) in the area where the fuel lines connect. Put the two side by side and you'll never forget the mental picture....
