Engine numbers - NCRS Discussion Boards
Engine numbers
  • Robert Carlino
    Engine numbers
    HI,
    I have a 1954 corvette I was missing some engine numbers at the last message new
    Block numbers are#0073260F54Y, If someone could email me back.
    Thank you
    Bob C
    email r.carlino@rcn.com
  • Chuck G.
    • May 31, 1982
    • 2029
    Re: Engine numbers
    Numbers still don't seem "right". The suffix should be F 54 YG, not F 54 Y.
    Also, the number suquence, should be more like 0732XXX, NOT 007XXX.
    What is the block number, located down near the fuel pump? Should be a "911" block. Also, what is the casting date of the block? That should be located above the starter, and in the format "A 1 4", Jan. 1, 1954, and so on. Chuck
    • Robert Carlino
      Re: Engine numbers
      Hi Chuck,
      I located the block casting numbers they are#3835911 they seem be the right.
      The engine numbers are #0073260F54Y I know a G should be there, is it possible
      it was never added very strange things went on around that time.The cylinder
      case casting # L is for December and I have a number 4 is that December 1954?
      Is there any other numbers I can check to confrim It is a matching numbers car?
      Bob C
      r.carlino@rcn.com
      P.S Carburetors # 2066SA all three....
      Thanks for all your help>>>
      • Wayne P.
        • August 31, 1975
        • 1025
        Re: Engine numbers
        I still say it's a truck engine.
