(Message Deleted by Poster) - NCRS Discussion Boards
  • Kevvie Fowler
  • William C.
    • May 31, 1975
    • 6037
    Re: Non Factory Side Exhaust - Pro or Con?
    Difficult to reverse, easy to detect, major deduct on the value of the car, to say nothing about the noise level if you plan on driving it.
    Bill Clupper #618
    • Rob A.
      • December 1, 1991
      • 2126
      I won't have another side exhaust car, after driving it for about 20 minutes, windows up or down, I'm tired of the noise. I think the noise from the standard, underneath exhaust system sounds just right..even after 20 minutes at highway speed. I've seen side exhaust added without t******* the fiberglass as the factory did. If you do it that way it can be converted back with much less trouble.
      • Kevvie Fowler
        Rob, was your side exhaust car a small block or big block? My vette has the std 300HP engine with that I heard it wouldn't be extermely loud but I have yet to hear it myself. Even if the side fiberglass can be spared can the valance in the back be added (to fill the holes) and removed easily?
        • Mike M.
          • May 31, 1974
          • 8365
          rear valence panel not a problem. remove the original with holes for exhaust extensions and replace it with a NO3 rear valence. save the original as you'll get tired of having a radio you can't hear. regards, mike
          • Kevvie Fowler
            If this car was converted and then reverted (assuming fg is not cut and original valance is kept) when ready to sell would this still have a major negative impact on value?
            • Mike Cobine
              Sidepipes are a funny thing. You'll find many who oppose them and many who think they are what sets a Corvette apart from other cars.
              I once drove from St. Louis to the other side of Dayton in a '67 coupe with a 427. Those pipes droned to the point that even with the speakers in the sides right next to our ears, we couldn't hear the 8 track playing.
              Still, I went to Nashville in '03 in a '72 convertible with sidepipes and had not one complaint about noise.
              Originality value will be hurt, and odds are replacing them back stock after you are done will be detectable, but you may find more who want them if you are in the selling mode. If you are not selling, you only have you to satis
              Recommendation: Find one with sidepipes and go for a ride. Either you will have a grin across your face that makes that $2000 option worth every penny or you will wake up in 4 days when you can hear again and say "never!"
              • Scott Marzahl
                Hooker side mounts are always an option
                You can also change the baffles in them, if you like the Hooker look.
                • Rob A.
                  • December 1, 1991
                  • 2126
                  It's a big block, with original G.M. pipes, but I've driven a 300HP with side exhaust and thought it was too loud also. Like I said, In my opinion, the normal sound from underneath car exhaust resonnating through the fiberglass body sounds just right. Before you add side exhaust, drive one for awhile, say a good 20 minutes or so and you'll know for sure if it's for you.
                  • Mike Cobine
                    Re: Hooker side mounts are always an option
                    Hookers on a midyear work better than on a C3. They seem to tuck under just a bit more, but either way, they are lady killers for sure.
                    You also get very wary wearing shorts.
                    A million years ago, Ecklers made some fiberglass covers for the header tube sidepipes that made a lot os sense for street use, but I've only seen them on the Ecklers cars in catalogs.
                    • Scott Marzahl
                      I think they look hot on a C2 and
                      with the mufflers don't sound bad either and cost less than half the GM repos.
                      • William C.
                        • May 31, 1975
                        • 6037
                        Re: I think they look hot on a C2 and
                        The one thing you have not mentioned in a potential reversal is the issue of the supports for the rocker panel that have to be removed/bent out of the way, or otherwisw dealt with to get the sidepipes installed. These can be a mojor PITA to replace/readjust or otherwise deal with if you find out later you want to change back. BTW, the loudest sidepipe car I ever owned was a '67 300hp version.
                        Bill Clupper #618
                        • Mike Cobine
                          The loudest one I ever owned was 112 dB on the A scale at 50 ft. It wasn't a 300 hp.
                          • Steve Shanks
                            Kewie, I'm in Indy, if you want to hear the sound from side exhaust let me know and we'll go for a ride.( stop by before spring though- I'm trying to find custom mufflers that would take the place of the chambers--my hearing is going bad)Steve
