Is there any way of telling if my 1966 BB Roadster came with the F41 Heavy Duty Suspension Package?
I'm in the middle of a body off & am not sure exactly what I have. The front spring appears to be HD but I am not sure if they are orignial or not (no lables or markings). The rear spring is a standard 9 leaf 2 1/4", however someone added a 5/16" x 1 7/8" x 7 1/4" rough cut steel shim plate between the differential housing & the top leaf.
Any clue as to why the shim plate was added?
I have the rear spring apart & plan on restoring. Is it worth the effort? Does the addition of the shim plate indicate someone believed the rear spring was shot or was someone just trying to adjust the ride height?
I am kind of lost here, any help or opinions would be greatly appreciated.
As Always Thanks,
Triple R
As Always Thanks,
Triple R
