C-2 powerglide leak - NCRS Discussion Boards
C-2 powerglide leak
  • Dave #35697
    C-2 powerglide leak
    O.k. It appears I have a phantom leak in the servo area.I have a gasket kit which includes the servo gasket and o-ring.
    Can I remove the servo cover,slide out the servo piston and replace the o-ring while Im there with out springs and other strange looking parts flying out at me?
    Or should I just relace the gasket?
    Thanks!
    Dave
    P.S. It only leaks when it hasnt been driven for 10 days or so.????
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C-2 powerglide leak
    Easy to remove the cover , you loose little fluid, if you think you need to replace the O ring pull the servo out using pliers, install it watching that the shaft cut out is aligned right.
