C1 Paint codes - NCRS Discussion Boards
C1 Paint codes
  • Michael S.
    • May 31, 2002
    • 91
    C1 Paint codes
    Can anyone provide me the following manufacturer paint codes ?
    1958 Panama Yellow
    1956 interior dash-red
  • Terry D.
    • May 31, 1987
    • 2690
    Re: C1 Paint codes
    Mike
    Check www.corvettepaintcodes.com or www.autocolorlibrary.com
    • Michael S.
      • May 31, 2002
      • 91
      Re: C1 Paint codes
      Thanks Terry. Would the interior red be the same as the exterior red ?
      • Ray C.
        • June 30, 2001
        • 1132
        Re: C1 Paint codes
        Exterior
        Du pont 2705-LH
        R-M A-1108-D
        Ditzler DDL 80986
        Interior Signet Red
        Du Pont 2704-LH
        R-M 8V52
        Ditzler DAL 70826
        Hope this helps!
        Ray
        Ray Carney
        1961 Sateen Silver 270-HP
        1961 Fawn Beige 315-HP
        • Michael S.
          • May 31, 2002
          • 91
          Re: C1 Paint codes
          Thanks Ray, a point of clarification if you don't mind.
          I understand the Panama code, the interior red code (maybe same as exterior red) I would like is for a '56. I believe that is Venetian. Is that 59388 ?
          Thanks very much.
          • Ray C.
            • June 30, 2001
            • 1132
            Re: C1 Paint codes
            Hi! Mike
            No problem, the name of the game is to get it right.
            Hi! Mike
            The information that I provided was from Complete Owner's handbook 1955-1962. There is a page with paint colors by manufactures with numbers for interior and exterior colors. The paint listings are also broken up into acrylic and regular lacquers. I did not provide the colors numbers for regular lacquers because I believe that they are impossible to purchase. The color name for 58 is listed as Signet Red for interior and exterior lacquers. At the bottom of the interior listing it states; to reduce gloss add Du Pont 4528 "DUCO" lacquer flattening compound or equivalent. Is it possible that when the interior colors were supplied that there was a reduction in sheen? Thus a different paint number, but the same color. I noticed that the Du Pont interior-exterior number was the same. The Corvette Black Book also lists Signet Red for the 58.
            Ray
            Ray Carney
            • Ray C.
              • June 30, 2001
              • 1132
              Re: C1 Paint codes
              Sorry! Mike my error; you were looking for 56 red interior not 58.
              Interior & Exterior listing: Venetian Red Du Pont: 2415-H R-M: 56V52 (regular lacquer) Ditzler DAL 70694 (Acrylic)
              Ray
              Ray Carney
                Re: C1 Paint codes
                The "flattener" was only used for the top of the instrument panel, between the eyebrow pad and the base of the windshield; the rest of the interior was exterior lacquer that wasn't buffed.
