C2 Plastic Rivet Installation - NCRS Discussion Boards
  • Donald T.
    • September 30, 2002
    • 1319
    Hi everyone! I'm attempting to install the plastic rivets on the ignition top shield on my 65, and not having much luck. I purchased the tubular rivet tool from Long Island and was able to rivet the front clip (after a major struggle!), but the tool does not seem to work on the plastic rivets. Everything I try just seems to tear them up. Any suggestions?
    Thanks!
  • Terry F.
    • September 30, 1992
    • 2061
    Re: C2 Plastic Rivet Installation
    I believe the plastic rivets you are talking about were melted flat with heat...not smashed like a steel rivet. You might try a hot kitchen knife. Good luck, Terry
    • Terry F.
      • 2061
      Also, the plastic rivets had a small steel washer that went on them before they were smashed flat. I assume we are talking about the one's that hold the thin shielding to the underside of the ignition shield. Terry
      • Donald T.
        • 1319
        Thanks Terry. I'll give that a shot!
        • Terry F.
          • 2061
          You are welcome. I hope we are talking about the same thing. Don't use too much heat. Terry
          • Donald T.
            • 1319
            Thanks Terry. Yes, those were the plastic rivets I was referring to. I heated the setting tool with just enough heat to get the plastic to flatten out over the washers. Worked just great!
            • Terry F.
              • 2061
              Excellent, glad to hear that. I never thought of using the setting tool. I have never had to do the repair but I thought if I had I would just use a hot spatuala or something similar. Sounds great. Take care, Terry
