Re: Duke - Squirrelly steering
OK, I am posting some photos of my two a-arms showing the shim stackup. Drivers side is on the top. The rear shim stack on the drivers side has .32 inches of shims (3 of them) and none in the front. On the passengers side, the rear as .56" shims and the front has only one shim at .15".
On my drive today I was able to further evaluate the centering feel. I definitely have a centering effect and the steering is tight. I am wondering if I have excessive "drag" or friction in my steering linkage somewhere. I mentioned in a different post that I have a new and VERY stiff idler arm. When driving at around 50 or so tracking straight on a level road, I feel as though to turn left or right I have to put a decent amount of force into the wheel to get a reaction by the car, and when that happens it feels like it sort of "jumps" to that position. I can rock the wheel back and forth and the car doesn't really respond at all, and then put just a bit more force into the wheel and then it reacts allot. It doesn't feel like there is an "in between". I think that is why it was feeling what I called "squirrelly", since it is difficult to make really small corrections and have the car respond. I have to put in more force and then the car over responds.
I am probably over-describing this as the condition is not really bad at all. I tried the same testing in a different late model car today also and the steering is much "lighter" to the touch and the centering effect takes it back right to where it started. In the Vette it is not that way, requiring more force to have a response and while it does have centering effect, it doesn't take the car back to dead straight. I know of course the cars are different but I was just comparing.
I wonder how much resistance the power steering cylinder has against turning while cruising at 50 or so? I was thinking of disconnecting my power steering cylinder and jacking up the front of the car to see what the steering feels like. I think it should be light right, with nothing to resist? At that speed power steering should basically be doing nothing since the forces should be too low to cause the valve to react.
Thanks for all the useful inputs!
