Warning: Undefined array key 1677 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
c1 exhaust -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I'm looking to put an exhaust system on my 56. There currently are straight pipes coming off of it now.
The carb is a carter AFB. I couldn't see a tag on the front, but the horn casting is 6-1593 and the body 0-1435. The intake manifold is a Edelbrock c4b. (Those are the only numbers I could see on it.) Engine is a bored out 327. Passenger side exhaust manifold is 3747042, couldn't read the numbers on the other side.
Ralph,
In all llkely hood, yes. The exhaust maniflods best come from a '06engine or earlier. altough later exhaust maniflolds will probably work OK. Can't locate the air horn #. Regards,
