C1 Vacuum line routing - NCRS Discussion Boards
  • Kevin Riel
    What is the proper way to route the vacuum lines on a powerglide and wiper/washer equiped 230 horse '59? I have a vacuum source on the back of the carb, and a drilled stud as per the AIM's for the powerglide cars. Where did the vacuum advance hook up? The vacuum modulator for the tranny, and the source that goes to the vacuum can for the wiper system? Thanks to all!
    Kevin Riel
    Re: C1 Vacuum line routing
    Kevin -
    W/Washer vacuum source was a fitting at the back of the carb baseplate. The modulator line hose came off the hollow carb stud to the steel line, and there was a tee inserted in this hose with another shorter hose to feed the vacuum advance. On manuals, the vacuum advance connected directly to the hollow carb stud.
    • Kevin Riel
      Perfect! Thanks. *NM*
