I found 4 bolts missing inside the rear frame bracket & had them replaced. I thought I finally found it. The clank sound is still there(not as bad though). My mechanic says the springs are fine & the car sits & rides well. Does anyone know where else I can look under the car to see what is causing this clank sound ? When I go over a speed bump or turn around a corner with a dip in the road (clank). The bushings all look fine. Is their a way to lubricate the leaf springs ? Could it be those liners inbetween the leafs ?
Thanks everyone,
Deb
Thanks everyone,
Deb
