for Joe lucia - NCRS Discussion Boards
for Joe lucia
  • lyndon Sharpton
    for Joe lucia
    Joe, I need a starter an I wanted a AC Delco. They list two part numbers for my car with manual transmission. they are 323-253 an 323-236, do you know which one is the best one? I am just using the car as a driver an wanted a good dependadle starter. than some of the 39$ rebuilds that the parts house have.
    • 43193
    Re: for Joe lucia
    lyndon-----
    I'm not sure that either of these will work on your car. Two questions:
    1) Is the car manual trans or automatic?
    2) Is the current starter nose made of cast iron or aluminum?
    • lyndon Sharpton
      Re: for Joe lucia
      Joe,
      the car is manual, cast iron
        • 43193
        Re: for Joe lucia
        Lyndon-----
        That's what I figured. Both of the starters that you mentioned have aluminum noses. One is designed for use on cars with 12-3/4" flywheels (which NO 454 ever used) and the other is designed for use on cars with 14" flexplates and auto transmission. The latter MIGHT also work for your application but I don't think that your car was originally supplied with such a starter.
        Anyway, you need starter Delco #323-254 or GM #1876552. If the Delco parts catalog specifies the above starters, then the Delco parts catalog is incorrect.
        • lyndon Sharpton
          Re: for Joe lucia
          Tahnks Joe!
