Fuel filter holder clean up? - NCRS Discussion Boards
  • jim #42767
    Any ideas if this will polish off. If so, with what?
    Re: Fuel filter holder clean up?
    Jim-----
    I don't think that it will. I think that there will be minor pitting if you are successful in "polishing out" the piece. What you have here is corrosion which has come through the plating of the bracket. To restore this as-original, it will need to be chemically stripped of existing plating and corrosion and then replated. Even then, the very slight pitting will still be visible. Since the pitting is as slight as it is, it may be possible to sand the pitted areas smooth before the replating is done. That should remove the pitting and make the surface appear smooth.
    • jim #42767
      Joe,
      Think this is a job for the chrome shop or should I just replace the piece?
      • Mike M.
        • May 31, 1974
        • 8365
        replating the original will almost certainly exceed cost of repo which are durn good repos. paragon good source. mike
        • Jim #42767
          You guys were right. I tried to clean it and polish it up but the pitting remained. I'll get another one from Paragon. Thanks!
          • Jim #42767
