396 chassis resto - NCRS Discussion Boards
396 chassis resto
  • Jeremy Hedges
    396 chassis resto
    I am restoring a '65 396 coupe for judging. What is the correct way to restore the front coil springs, the front and rear sway bar to achieve the correct apperance for judging?
    Jeremy
    #31711
  • Bill W.
    • March 1, 1980
    • 2000
    Re: 396 chassis resto
    If your coil springs are still good you can clean them by glass beading or having them dipped at a ready strip. The sway bars and springs were heat treated .The finish was dark blueish to black. if they are not to rusty dipping will preserve this finish. I have had good luck duplicating this look using metal conditioner and gun blue. practice on your rag joint it has the same finish...Bill
