tire cradles - NCRS Discussion Boards
tire cradles
  • lyndon Sharpton
    tire cradles
    anyone use these? if so how do you like them. do they seem to work?
  • Timothy B.
    • January 1, 2004
    • 438
    Re: tire cradles
    OK, I'll bite. What's a tire cradle? I have heard that some of us baby our cars, but this may be too much!! :-)
    • lyndon Sharpton
      Re: tire cradles
      it is some kind of floor matt for your tires. that is susposed to keep them form flat spotting.
        Re: tire cradles
        Modern tires don't permanently "flat-spot" like some older tires did; any flat-spotting is temporary, and disappears in a couple of miles of driving. Any tires that are old enough to flat-spot are old enough that they shouldn't be driven on anyway.
        • Wayne K.
          • December 1, 1999
          • 1030
          Also, if your car is being stored and...
          your concerned about flat spotting just air them up to 45-50 psi and they will be just fine.
          Wayne
          • Rick S.
            • March 1, 2004
            • 14
            Maybe Wheel Dolly?
            Their slightly rounded on the bottom for the wheels.
            Good to push the car around the garage.
            • Mark Heff
              Tire Cradles
              Lyndon,
              I own a set of tire cradles. I really like them. I think they are worth the few hundred dollars, especially if you don't have a heated garage. It's better to have rubber on rubber, simple as that. You can pump your tires full of air, etc. But I prefer to keep tires a little over the required pressure and park them on the tire cradles. It might be more for mental comfort, but so is that correct Alternator I'm in search of !
              Also, their website at TireCradle.com is very thorough and tells you everything you need to know. They have performed many tests with their product and have the data to prove it.
              I feel better parking an expensive sports car on top of this rubberized material instead of on top of an extremely cold or hot floor. I'm not even worried about flat spots, I just like the feel of it.
              Just my .02 of course.
              Mark
              • lyndon Sharpton
                Re: Tire Cradles
                Thanks guys!
                • Scott Marzahl
                  Wheel dollies are worth it.
                  I picked up a set of wheel dollies from Harbor freight on sale for something like $40. They're great, you can puch the chassis or car around out of the way while you are working on something else.
                  • Terry F.
                    • September 30, 1992
                    • 2061
                    Re: Wheel dollies are worth it.
                    I bet wheel dollies would work well for aligning the front and rear of the car for the do it yourselfer. They would give you the extra clearance to get under the car to make adjustments and they would alow the wheels to move as needed for making the adjustment. What say all? Terry
                    • Scott Marzahl
                      Now that sounds like it might be a good idea *NM*
                        • 15610
                        You don't need to get "under the car" to make camber and caster adjustments on a Corvette - only toe in, which is easy.
                        Wheel dollies won't allow the suspension to settle - bad idea.
                        • Pat #25912
                          My wheel dollys, with a completed car on the 4 of them, only roll "easily" in the direction the wheels are pointed. In other words, when I want to move my car I have to unweight each dolly and turn the wheels in the direction I want them to go. Utherwise they are great. Pat G.
                            Pat -
                            Those appear to have the cast iron wheels; I've had a set of Car Skates (www.carskates.com) for many years, and they have polymer wheels with a slightly convex surface and ball-bearing pivots, and I can move a car around (and change direction of movement) with one hand.
                            • Pat #25912
                              Good eye John...
                              You are correct. This set was about $50 at Costco. They work but if the car skates work that much better I will get a set this summer. Thanks for the tip. Pat G.
