C1 Antenna - NCRS Discussion Boards
C1 Antenna
  • Peter Cipriani
    #1
    C1 Antenna
    On 61/62 does the mast of the Antenna completely retract into the fender? Mine seems to be original and sticks up about 10" approx. from the fender. The JM has me confused on this issue?
    Also, I tried to polish the mast and found out that it is made of brass or copper. Not a good idea $$$$$$$$$$$$
    Do any of the Corvette supplier's sell the mast only?
  • Dave S.
    • August 31, 1992
    • 2918
    Re: C1 Antenna
    Peter,
    The lower part of an original antenna mast should slide up and down within the antenna body. When lowered fully it will be about 8" above the fender and when extended it will be about 14" or 16". The repros don't do that as the lower part is fixed. Paul Mazut can help you with whatever problem you have.
    • David Lyon
      Re: C1 Antenna
      Dave,
      Do you have contact info for Paul?
      David
      • John M.
        • January 1, 1999
        • 1553
        Re: C1 Antenna
        David,
        You can allways contact Paul by clicking on his name in the user profiles. Paul is the man for C1 antennas, and a damn nice guy to boot!
        Regards, John McGraw
        • David Lyon
          Re: C1 Antenna
          Thanks John! Will follow your direction. David
          • Debra P.
            • September 30, 2004
            • 147
            Re: C1 Antenna
            Hi Peter,
            Try calling J.T.Piper auto in IL. 800-637-6111 ask for James, he might have the antenna mast you are looking for.
            Cheers,
            Deb
            • Dave S.
              • August 31, 1992
              • 2918
              Re: C1 Antenna
              David,
              You can email him as John pointed out or call him at 413-243-3439. He will be able to fix whatever problem you may have.
              • David Lyon
                Re: C1 Antenna
                Thanks, Dave! I just sent Paul an e-mail as an initial contact. Hope to call him
                later.
                David
