Posted this question some time ago, got absolutely no response.
How can you tell if you need to change out the rear crossmember cushions/bushings (I think some of you refer to this as the sombrero cushion or bushing)?
I am at the point of reassembly where I need to make a decision quick.
If I knew the exact procedure for changing it out I would not hesitate. Unfortunately I haven't been able to find anything that tells me how to go about it. therefore I am afraid to attempt it.
I don't know if it is a do-it-yourself project whether special tools are needed or not.
I know many of you had to make this same decision. What did you do? Is the change out something that is fairly simple & I am making too big a deal out of it.
As I stated in my last post I search the archives to no avail. All I could find was how difficult it was to remove the crossmember from the frame. Not a word about evaluating or changing out the cushion/bushing or reinstallation of the crossmember with the new bushings.
I could sure use your knowledge & experience. Is there anyone out there?
Sorry for the begging, just trying to do the right things right.
Triple R
Triple R
