Gentlemen:
Need your collective wisdom please.
68 coupe with power brakes.
Symptom: Pedal goes to within 1/2 inch of floor board before vehicle comes to complete stop.
Professionally rebuilt power brake booster and master cylinder(bore was stainless steel sleeved).
Fluid level (Dot 3)in master cylinder is perfectly clean and clear and remains constant so I assume there are no leaks. No leaks apparant at wheel calipers (stainless steel sleeved) and no fluid on ground.
Car is not driven (still in restoration process) and system was completely rebuilt within last 12 months and driven only back and forth in driveway and brakes were perfect until today. Pumping up pedal changes nothing so I am assuming I do not have air in the lines.
Did my master cylinder go bad while car was sitting in garage?
Any input or suggestions welcomed.
Thank you in advance,
