C1 wiper motor ground wire... - NCRS Discussion Boards
  • Pat #25912
    The AIM seems to show the wire terminal sandwiched between the wiper motor mounting bracket and the mounting plate, ie: screw, bracket, wire terminal, then mounting plate. I would think that putting the wire terminal between the screw and the mounting braket would make more sense. Is the AIM correct? Thanks again. Pat G.
  • Mike E.
    • February 28, 1975
    • 5134
    Re: C1 wiper motor ground wire...
    AIM illustration is not correct.Ground wires sits on top of wiper motor lower bracket--screw affixes wire to bracket, then bracket to mount plate.
