60 Wiper moter mount bracket screws - NCRS Discussion Boards
  • Larry P.
    • June 30, 1999
    • 481
    What are the proper nuts for the underside of the dash for the two screws that secure the wiper motor mounting bracket?
    (Sorry guys, I didn't take this thing apart)
    Larry
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Re: 60 Wiper moter mount bracket screws
    Larry, Don't recall they're anything special. 1/4 20 nuts with a flat and lock washer. They be a little hard to see anyway...
    • Larry P.
      • June 30, 1999
      • 481
      The bolts I have, that I believe go with it, are not 1/4 20. They are phillips
      head fine thread. I thought they might use the twist on nuts similar to the ones that hold the transmissions in place.
      Larry
      • Ed Jennings
        Larry, I'm with Dennis, I don't remember them being anything special. I would think they are a pan head Phillips screw. They are probably 1/4-20 X 3/4 or 1", as there is no reason for this applicaton the be fine thread. The 1/4-20 could have used a cut nut, but more likely a regular nut with washer. Have you looked in the AIM? There is probably a picture that might give a clue.
        • Ed Jennings
          Addendum
          I found a picture of the assy in the 61 AIM. What it shows is the screw,then a lockwasher, screw through the plate and body, and a nut (no washer) on the bottom side. Don't forget that the right hand side also has the ground wire that attaches to the valve cover screw.
          • Larry P.
            • June 30, 1999
            • 481
            Re: Addendum
            Ok, I can't find it in th 60 AIM. That doesn't mean it's not there. I'll just use th 1/4 20s.
            Larry
            • David Lyon
              Larry,
              CC has the complete mounting kit with bolts, nuts, washers etc. That's what I used when I reinstalled my wiper motor and motor mount plate with drum on my '58.
              David
