Does GM still sell head bolts for the L89? If so can someone tell me the part number? Thanks
C3 L89 Head Bolts
Re: C3 L89 Head Bolts
Ted,
The head bolts for your L89 with AL heads would be the same part used for conventional cast iron heads for any big block of the era. The original head bolt part number shows still available from GM but I believe the configuration of the head is much different than those used in 1967-69. There is a hardened steel washer listed for, depending on how you read the book, an L89.
The original, and current numbers are...
3877668.....Head bolt, long
3877669.....Head bolt, short
3899696.....Washer, head bolt
Michael- Top
ted-----
All original big block head bolts had a raised "cross" (+) on the head. The cross was wide and the "legs" extended to the perimeter. The bolts were "untrimmed" (indented head) and they were a flange head type bolt. The wrenching surface was 5/8" across-the-flats.
The current versions of the bolts available under the original part numbers are configured "more-or-less" like the originals, but NOT exactly like the originals. They have a "cross" (+) on the head but the cross is much smaller and "thinner". The "legs" do not extend to the perimeter of the head. The bolts are "untrimmed", but the "indention" is less pronounced than the originals. The bolts are flange head, but the flange is less pronounced than the originals, too. They are 5/8" across-the-flats just like the originals, though.
Using new head bolts is a good thing to do, however. This is especially true if you don't know the history of the bolts and, consequently, their condition. "First run" head bolts (installed at the factory and removed for the first time) are usually ok for re-use. All others are suspect and I would not re-use them. You don't know what torque that some "genius" may have applied to them. Torqued to the yield point (or, nearly so) and the bolts are ruined.
So, keep in mind my old "axiom": reliability and functionality FIRST; originality SECOND. At least, keep this in mind if you intend to drive the car.In Appreciation of John Hinckley- Top
