c-2 (65) gas mileage - NCRS Discussion Boards
  • David H.
    • December 1, 1996
    • 241
    Hey all; Am helping a freind with a 65 300hp/glide car and 3;36 gears. the car runs good but gas mileage is 10.5/gal.. We found bad points and a closed exhaust crossover vlv. Is it posible that the metering rods and jets are actually worn in the carb. idle screws work great and trans downshift is set right. Thanks in advance; David
  • David H.
    • December 1, 1996
    • 241
    Re: c-2 (65) gas mileage
    Carb. is a carter AFB. David
    • Timothy B.
      • April 30, 1983
      • 5177
      David,
      I would first start by installing a new heat riser valve or getting the old one to move freely, then pull the spark plugs and note the condition and color of the plugs. If you have a 63 shop manual there is a section on tune up and it describes what a spark plug should look like under normal operating conditions. If the plugs look good your problem may not be in the carburetor and a tune up with points, condenser and spark plug wires may be in order. It's also a good idea to pull the distributor, clean, lube and check the centrifugal and vacuum advance to be sure all is working and free moving, this will not cost anything just some time.
      If the carburetor does not leak and the engine doesn't smoke with black rich smoke I would not touch the carburetor until last but I guess anything is possible with regard to metering rods and jets being wore out.
      • Don H.
        • December 1, 1981
        • 1482
        I had a 64 years ago that got very poor mileage when I bought it. The problem was the vacuum advance in the distributor. For reference, the car should get around 16 mpg on the highway (14 with ac on). I have put over 100k miles (total) on three midyears, all 300hp auto. Don H.
        • David H.
          • December 1, 1996
          • 241
          Thank you Tim and Don, I was thinking the mileage should be just what Don said and I will check out the vacuum advance next. the exhaust valve is wired open now with a new one on the way. David
          • Mark G.
            • March 1, 2001
            • 227
