Heater box questions 65. - NCRS Discussion Boards
  • Jim #42767
    Got the heater box out on my 65 to replace the core. Now that I have the box apart, I have some questions:
    (1) There is some surface rust covering the metal partition in the box behind the heater core. Should I bother trying to clean it up? If so, what should I use? I was thinking about using naval jelly, then flushing with water, but I don't want to damage the fiberglass heater box. Any suggestions?
    (2) I will be replacing the foam insulation on the flapper door; what is the best way to clean & prep the flapper door surface?
    (3) In order to gain access to the inside of the box, I have removed the metal cover that is riveted to the fiberglass. How do I replace these rivets, is there a special tool to replace them?
    (4) Anything else I should do while I have it out?
    Sorry for the long post, but I only want to have to do this once...
    Thanks in advance for all advice & information
  • Harry Sadlock
    Re: Heater box questions 65.
    Jim, The answer is much longer than your question. If you don't mind a phone conversation, send me an email with your phone number.
    Harry
    38513
