BW-T10 1962 Into 1957 - NCRS Discussion Boards
  • Bob Kupper #39064
    Will the BW-T10 from a 1962 vette drop directly into my 1957 Fuelly 3 speed?
  • Roy B.
    • February 1, 1975
    • 7044
    Re: BW-T10 1962 Into 1957 YES *NM*
    • Tom D.
      • September 30, 1981
      • 2126
      Small Diameter front bearing cover?
      Roy - Do you know the diameter of the three speed bellhousing hole? Same as the outer diameter of the "front bearing cover" on the trans.?
      Tom D.
      MichiganNCRS.org
      https://MichiganNCRS.org
      Michigan Chapter
      Tom Dingman
      • Bernard M.
        • August 31, 1994
        • 341
        You may have to change the bracket that bolts to the tailshaft. I think you will find a difference in the spread of the bolt holes on the tailshaft housing. I don't have any reference material in front of me at the moment to check but it would be a simple fix, just use the later style bracket.
        • Christopher R.
          • March 31, 1975
          • 1599
          I believe it'll fit. Not sure about the bell housing. But I know the shifter and the yoke will fit.
          '62 only had a mounting bracket for the rear tailshaft that hooks up with the existing rear bracket. All the vendors carry it.
          • James F.
            • December 1, 1985
            • 596
            B;ob. Roy gave you the aswer. Ask the question to someone old enough to have doen the job several times in the late '50's! They'll know, Roy and I ualify!! Hower, might want to check he heigth of the crossmember rubbber buscit and kep the rubber mount with the T-10. Regards,
            • Roy B.
              • February 1, 1975
              • 7044
              Re: Small Diameter front bearing cover?
              I don't really know the diameter , BUT any year 3 or 4 speed , that any G.M used will bolt up to your bell housing, all are the same .
              That's why stinking Ford guys use Chevy engines and trans.
              Oh no ! any one own a FORD!!!
