66 ground strap near brake block goes where? - NCRS Discussion Boards
  • Dave#24235
    I am not sure about the correct place to attach the other end of the ground strap that is bolted to the frame near the brake block. I assume it connects to a harness or electrical part, but doesn't look long enough to reach the alternator or regulator - both of which are above it in my A-C, PB, BB roadster.
    Is it supposed to be there? If so does anyone know where it connects?
  • Bob R.
    • June 30, 2002
    • 1595
    Re: 66 ground strap near brake block goes where?
    I believe the ground strap you are talking about is the ground to the engine from the frame. It connects to the upper A arm on the drivers side and to the engine mount bolt on the block.
    • Randy S.
      • January 1, 2003
      • 586
      Is this for BB cars only?
      radio equipped cars get this on passenger side see U69 A4 but I could not find driver side strap in the AIM
      Randy
      • Eugene B.
        • May 31, 1988
        • 710
        Dave,
        I'm going to make the assumption that my '65 and your '66 are the same in this regard.
        If you are asking about a ground strap that is approximately six inches long and has a larger ring terminal on one end that the other, it is used to ground the engine. Remember that the engine is setting on rubber mounts.
        I cannot find it in the AIM but it is discussed in the TIM & JG under the category "Front Engine Mount Assemblies and Ground Strap." It is secured at the frame and the upper forward engine mount bolt.
        Hope I've done an adequate job of explaining. Good luck.
        Gene
        • Stephen L.
          • May 31, 1984
          • 3148
          The ground straps typically appear in the AIM under U69 option....radio option.
          Check it out
          • Dave#24235
            The motor mount strap exists. This is another one
            There is a much longer one bolted into a threaded hole in the frame near the brass brake block.
            • Randy S.
              • January 1, 2003
              • 586
              Gene,
              The TIM&JG says radio cars have this on the left side only and the 66 AIM (u69 A4)shows this on the pass side.???
              Randy
              • Eugene B.
                • May 31, 1988
                • 710
                Randy,
                Great observation. This looks like a mystery to be solved.
                Indeed the TIM & JG states that the ground strap is on the left side only. In the '65 AIM, section U69, page A4 (E418) it shows the g-strap on the RH Engine Mount Asm.
                What I know is my March '65 has the g-strap on the left side only per the JG. Perhaps others will comment.
                Thanks again for your input.
                Gene
                • Dave#24235
                  My L36 A-C car has a LH engine mount strap
                  But the strap near the brake block is not that one. Is it supposed to be?
