58-59E rubber bits on female... - NCRS Discussion Boards
  • Pat #25912
    hood latches, were they installed by the General or by Bubba? The rubber part is a piece of vacuum hose about 1-1/4" long on the spring where it contacts the arm (both latches). I think the only purpose it serves is to add tension to the spring. Was the rubber in place from the factory or should I be ordering new springs? Thanks again. Pat G.
  • Paul M.
    • November 1, 1987
    • 142
    Re: 58-59E rubber bits on female...
    No rubber on the catchs. Cut if off and see how they work.If ok don't order new ones other wise do so.
