C2: Help interpreting some 1965 numbers - NCRS Discussion Boards
  • Barbara S.
    • April 30, 1981
    • 599
    Hi all. I need some help interpreting some numbers on a 1965 Roadster. The engine stamping pad reads:
    5107483 F0II4HT
    I'm a C1 guy, and I'm looking at a C2.
    Any help would be greatly appreciated.
    best regards,
    Tony
  • Wayne M.
    • March 1, 1980
    • 6414
    L79, no C60, no K66 assembled Jan 14th, then...
    ... installed in '65 Corvete VIN # 07483.
    • Wayne M.
      • March 1, 1980
      • 6414
      • Barbara S.
        • April 30, 1981
        • 599
        Re: L79, no C60, no K66 assembled Jan 14th, then..
        L79 is a 327/350?
        What do C60 and K66 stand for?
        • Barbara S.
          • April 30, 1981
          • 599
          L79 is a 327/350?
          • Wayne M.
            • March 1, 1980
            • 6414
            Yes, L79 is 327/350hp; C60 is air conditioning, and K66 is transistor ignition. You could have gotten the L79 with either additional option or both, or neither (in this case) so there's 3 more engine suffix codes to cover those combined option versions.
            • Wayne M.
              • March 1, 1980
              • 6414
              • Barbara S.
                • April 30, 1981
                • 599
                This car has no A/C.
                • Barbara S.
                  • April 30, 1981
                  • 599
                  • Donald T.
                    • September 30, 2002
                    • 1319
                    4 speed also *NM*
                    • Donald T.
                      • 1319
                      4 speed also *NM*
                      • Donald L.
                        • September 30, 1998
                        • 461
                        Tony,
                        If this C-2 had been originally equipted with AC , Transistor Ignition, Manuel trans. and L-79 the pad would have been coded "HW".
                        Donald #31176
                        • Donald L.
                          • 461
                          Tony,
                          Donald #31176
                          • Barbara S.
                            • April 30, 1981
                            • 599
                            Thanks guys! *NM*
                            • Barbara S.
                              • April 30, 1981
                              • 599
                              Thanks guys! *NM*
