59 along the top of pass side inner fender... - NCRS Discussion Boards
  • Pat #25912
    I believe there should be 4 holes for screws. I had about 6 so I filled them all. Now I want to dill out the needed holes. The front one is for a strap that goes around the fresh air intake hose and I have drilled that one. How far apart are the next three? And, is it clip for red wire then another hose strap then another wire clip? Thanks. Pat G.
  • Richard F.
    • January 1, 2005
    • 46
    Re: '59 along the top of pass side inner fender
    You are correct. There are 4 screw holes spaced as follows- from forward edge of heater box measure forward 3" (clip screw hole), then 7" more inches (clip screw hole), then 7" more(strap holder screw), then 8" farther forward (strap holder screw). You should now be 8" behind the pass side rad frame mount which includes the heater intake hose mount plate.
    Note there are two fresh air intake straps side by side utilizing the first two holes from the front.
    HTH
    Richard
    Also just a little aside. Your red wire is black on mine. I believe this is the original by look, feel and end connections. Comments on this please.
    • Richard F.
      • January 1, 2005
      • 46
      HTH
      Richard
      • Pat #25912
        Thank you Richard. That is what I needed. *NM*
        • Pat #25912
