70 tach valve - NCRS Discussion Boards
70 tach valve
  • Dennis D.
    • March 1, 2000
    • 1071
    70 tach valve
    This valve is mounted on the rear of the tach housing. Has a electrical connector, and 2 vacuum ports.(from overide to headlight switch) Now that I overexplained this, here's the question. On the plastic port end there's a small hole in the end. Is this a bleed hole or just time for a new valve?
  • Michael W.
    • April 1, 1997
    • 4290
    Re: 70 tach valve
    It's broken. Good luck finding a replacement!
    • Michael W.
      • April 1, 1997
      • 4290
      Re: 70 tach valve
        Re: 70 tach valve
        Dennis-----
        I'm not sure that the valve is bad. There's supposed to be a foam "filter" over the end, but it's not critical. Does the wiper door system work alright when turned on at the wiper switch with this valve installed? If it does, the valve must be alright.
        The valve (actually a vacuum switch) was GM #5638276. It's GM-discontinued and has been for a long while. It's not currently reproduced and it's hard to find. There's an NOS example on eBay right now (eBay #7948277325). It's only at $41 right now but I'll bet it's a lot more "when the gavel comes down".
          Re: 70 tach valve
          Dennis-----
          • Dennis D.
            • March 1, 2000
            • 1071
            Re: 70 tach valve
            Joe
            It functions fine. Is the hole OK or should I epoxy over it
            • Dennis D.
              • March 1, 2000
              • 1071
              Re: 70 tach valve
              Joe
                Re: 70 tach valve
                Dennis-----
                No, I would absolutely not epoxy over it. I believe that the hole is intentional and necessary.
                  Re: 70 tach valve
                  Dennis-----
                    Joe's 100% correct!
                    The hole is what allows vac to vent and raise the wiper door when you turn on the WSW switch! If you plug it all (*&& is going to break loose in terms of consistent operation....
                    As Joe and others said, the original relay valves had a rectangular 'chunk' of foam rubber covering the vac vent port that did a 'modest' job of filtering air. This foam isn't really necessary as you have an in-line vac filter on the system as a whole between the intake manifold and the check valve. The vent tube on the wiper door safety switch simply ran through a cowl grommet and sat 'open' in the engine compartment (no discrete filter on it)....
                    But, if you feel better with a filter on your WSW electro-vac relay behind the dash, go cut a 1 x 1 inch square, roughly 3/8-inch thick of VERY porous foam rubber, square the end of the vac vent tube, apply a circular bead of cyanoacrylate (super glue) and stick the foam in place....
                      Joe's 100% correct!
