my 69 built date - NCRS Discussion Boards
my 69 built date
  • frank
    my 69 built date
    can someone help please
    my 69 corvette built date is E17 ...... wich month is "E"
    Frank
  • Harry Sadlock
    Re: my 69 built date
    Frank, try --->
    with you vin seq number to get a pretty accurate build date.
    According to the NCRS pock guide E is January 1969.
    Harry
    38513
    • Harry Sadlock
      Frank, try --->
      Harry
      38513
      • Harry Sadlock
        Frank, also, the E17 does not represent the build date. It represents, as I recall, the day the tag was put on the car, not when it reached the end of assembly.
        Harry
        • Harry Sadlock
          Harry
          • Dick W.
            • 10483
            But the date usually is within a couple of days or so of the build date
            Dick Whittington
            • Dick W.
              • 10483
              Dick Whittington
              • Mark #28455
                "E" is December 1968 *NM*
                • Mark #28455
                  • Harry Sadlock
                    Re: "E" is December 1968
                    Mark is correct, I'd better clean my glasses.
                    Harry
                    • Harry Sadlock
                      Harry
                      • frank
                        ok great .... let say it is december 68
                        my vin number is 11003 and built date is E17
                        does it sounds possible that the 11003 car was made in december ?
                        should all date appearing on parts should be 68 or 69 ?
                        (EX: rear lignts, flashers, side lights, front lights ect ...)
                        thanks
                        Frank
                        • frank
                          thanks
                          Frank
                          • Mark #28455
                            Last car built NOv 68 was 9159. Last car built Dec 68 was 11742.
                            Dates on parts are variable, for instance, many of the exterior light lenses were also used in 1968, so those lenses will all be 68, but certain lenses were new for 69 like the tail lights with the backup lights so they will be 69. The trans will be for a 69 "model year" so for muncie the date code will start with P9 even though it was assembled in 1968. Consider buying the NCRS judging guide as the third revision is really good at detailing these things. Another good book is the 1969 Guidebook by Bizzoco.
                            Good luck,
                            Mark
                            • Mark #28455
                              Good luck,
                              Mark
