Engine Builder in NC/SC? - NCRS Discussion Boards
  • Mike (33053)
    I'm trying to identify an engine builder with modern machining capabilities in North or South Carolina. Have any of you had good first-hand experience with one?
    The project is a '66 L72. I want to keep the appearance original (942 block, 858 heads, 827/8 exhausts, 069 intake, 3247 Holley), while updating and enhancing internal components. My plans include balancing, blueprinting, mild head work, stroker crank (nothing too wild), forged pistons (9.5 to 1, more if I thought I could get by on pump gas), roller cam, and roller rockers (if they'll fit under stock valve covers with an extra thick gasket).
    Thanks in advance for your help.
    Mike (33053)
  • Peter J.
    • September 30, 1994
    • 586
    Re: Engine Builder in NC/SC?
    Mike,
    Give Steve Ashworth (Ashworth Racing Engines)919/552-9615 a call. He is located in Fuquay Varina south of Raleigh. He rebuilt my 66 L-79 and I am satisfied with the performance. He is primarily a race engine builder and knows how to get the horsepower you want with the type of modifications you are thinking about. I resisted the dual profile cam and other mods he wanted to make because I thought the stock L-79 was quick enough for my needs. The only problem I`ve had was the use of silcone for oil pan seals (leaked like crazy after a couple thousand miles) He knows his stuff. Good luck, Peter
    • Jeff Burkey
      Mike, if you need someone in the Charlotte area, I can personally recommend Rick Elgin, or Jeff Williams at Elgin's Corvette Specialty. They are able to perform any and all work you may need and have relationships with machine shops that do nothing but work on NASCAR Winston Cup engines. They can be reached at 704-821-8388. Good Luck!
