eastwood - NCRS Discussion Boards
eastwood
  • lyndon Sharpton
    eastwood
    Has anyone used the eastwood carb paint? how close does it match the finsh of the OEM look? are would you just send it out to be redied?
  • Craig S.
    • June 30, 1997
    • 2471
    Re: eastwood
    I have not used it but seen it on a carb at the Eastwood booth at Carlisle. To me it does not look good.......and restoraton by someone like Jerry Luck, Jerry MacNeish, or Bob Kuntz is the only way to go......Craig
    • Craig S.
      • June 30, 1997
      • 2471
      Re: eastwood
      • Eugene B.
        • May 31, 1988
        • 710
        Re: Also consider
        Gents,
        In addition to the folks listed above, I'll give a very positive report on Dick Katter at Eaglehead Restoration.
        He restored my Carter WCFB and it looks beautiful. Almost too nice to put on the car and drive around. Looks like it should be setting on a coffee table or in a china cabinet!
        Good Corvetting to all,
        Gene
        • Eugene B.
          • May 31, 1988
          • 710
          Re: Also consider
          Gents,
          Gene
          • Dennis A.
            • April 30, 1999
            • 1010
            Re: eastwood
            Lyndon...
            I would never paint a carburetor,unless the car is going into a museum.
            • Dennis A.
              • April 30, 1999
              • 1010
              Re: eastwood
              Lyndon...
              • Gerard F.
                • June 30, 2004
                • 3803
                Tried it, it sucks!
                I tried it on some fuel bowls, before I got my copy cad/zinc plating kit(Caswell). The carb finish looks painted and you can't get that gold irridescent finish. It comes out dull gold or bronze and looks more like a coating.
                I also tried the their golden cad system for bright metal parts. I looks reasonably well but you can still tell it's a coating, and it is soft and scratches easily.
                On carburetor pot metal parts, you don't even have to replate with zinc to get a good finish. All you need to do is to buff them down to bright shiny metal finish to bare some fresh zinc, and then dip them in Yellow Dichromate (which I got with the plating kit). On steel parts(like bolt heads and levers) you have to plate a coat of zinc first before you dip in the yellow dichromate. If you polish up the zinc plating before the dip, it comes out to a bright gold finish.
                Here's a carb I replated, after I removed the painted finish from the fuel bowls:
                But it took many hours and lots of practice runs.
                There was a recent post also, where you can send the carb to Holley for a refinish job for $150.
                Jerry Fuccillo
                #42179
                Jerry Fuccillo
                • Gerard F.
                  • June 30, 2004
                  • 3803
                  Tried it, it sucks!
                  Jerry Fuccillo
                  #42179
                  Jerry Fuccillo
