Wont your response welcomed - NCRS Discussion Boards
  • Garry Barnes
    Re: Wont your response welcomed
    Thanks Roy. As always, you are extremely helpful especially on the detail stuff. Question, is it safe to say, with the exception that they are not one piece ,that the configuation of the currently available reproduction header w/s is incorrect in terms of fit and or overall configuration?
    Garry
    • Garry Barnes
      Garry
      • Roy B.
        • February 1, 1975
        • 7044
        #18
        Re: Wont your response welcomed"Garry" YES *NM*
        • Roy B.
          • February 1, 1975
          • 7044
          #19
          • Roy B.
            • February 1, 1975
            • 7044
            #20
            I should have mentioned - that is the reason people complain about leaks and that they don't know how to add those hard rubber blocks they sell for the corners which were never used, ( that's why) I should write you off post and others on such things when asked. I seem to rock the boat with many )
            • Roy B.
              • February 1, 1975
              • 7044
              #21
              • Garry Barnes
                #22
                I never knew where those blocks of rubber were to go either, therefore I always throw them away. They certainly don't fit well anywhere. Aside from that, I think the majority of us would rather have you post here and at least challenge some of the current thinking. You always seem to be able to provide proof of what you are challenging which is not always the case with those that are "in the boat" as you say. Thanks again and if you ever go take more picture of the original '57 up the street, take a shot of the paint margins on the underside of the hood for me. It is still not clear to me how that is suppose to look. Also, inside the trunk at each side around the wheel wells would be interesting to see just how much paint was applied. Thanks. I for one am a Roy fan!
                Garry
                • Garry Barnes
                  #23
                  Garry
