Re: No biggie Elm
Well I finally got the differential out of the car!
I ended up removing the 4 bolts on the top of the carrier cover to crossmember bolts because I couldn't get the crossmember loose from the rubber mounts if my life depended on it. I will need to devise a way to get this crossmember off now that the axle is out of the way. It appears that the axle has never been removed from the car- Based on the clean paint still under the mounting points and a 2 letter label still attached to the differential cover. The bad news is that it a 3.70 OPEN END! Yikes! why would anyone order such a thing?
Oh well, that's another project. Thanks again for all the advice!
Elm.
Elm.
