66 BB Engine re-build - NCRS Discussion Boards
  • Hector G.
    • November 1, 2004
    • 234
    I'm considering rebuilding a 427/390 HP engine. I live in So. Cal. Does anyone know a good engine builder, someone familiar with these engines. Also, does anyone have any ideas on whether the engine's specs should be kept as close to original or modified. Finally, has anyone heard of Derek Smith. He is from Ohio and builds Corvette engines.
    Thanks for your input.
    Hector
  • Rory Riedy
    Re: 66 BB Engine re-build
    While Hector has your attention. I will be at the same point he is currently within the next few months (a '66-427/390 Rebuild). However I am in St. Louis, Missouri. Can anyone recommend a reputable rebuilder in the St. Louis area?
    Hector,
    Sorry to horn in on your tread like this, but I was going to post the same question in the near future. Hope you get the information you are looking for.
    As always a 1,000,000 thanks up front
    Triple R
    • Rory Riedy
      Hector,
      Triple R
      • Rob A.
        • December 1, 1991
        • 2126
        Superior Performance in Anaheim, I can give you their # if you like, I'm in Mission Viejo, CA. Not cheap, but they work with these engines all the time.
        • Rob A.
          • December 1, 1991
          • 2126
          • Hector G.
            • November 1, 2004
            • 234
            Thanks Rob. What is the number?
            Hector
            • Hector G.
              • November 1, 2004
              • 234
              Hector
              • Rob A.
                • December 1, 1991
                • 2126
                Superior Automotive, Anaheim, CA 714-503-1880. (Get a written quote for the work before it's done)
                • Rob A.
                  • December 1, 1991
                  • 2126
                  • Hector G.
                    • November 1, 2004
                    • 234
                    Thanks Rob.
                    • Hector G.
                      • November 1, 2004
                      • 234
                      Thanks Rob.
