Rear Center section ID help - NCRS Discussion Boards
  • Dave S.
    • August 31, 1992
    • 2918
    I am looking at a center section with the following information either cast or stamped on it.
    Casting number: 3789812
    Casting date: A 3 11
    Stamped information: FP 213
    It currently sits in a 62 FI metallic brake car. It has the correct elongated P. I have looked at all the numerous books I have and can't find the FP code.
    Any help in decoding the above is greatly appreciated.
    • 11608
    Re: Rear Center section ID help
    1963 Pontiac Catalina with a Powerglide
    Sorry. Just couldn't help myself.
    Good to talk with you yesterday.
    Patrick
      • 11608
      Patrick
      • Dave S.
        • August 31, 1992
        • 2918
        Thanks Patrick,
        do you know the ratio.???? Nice to speak w/ you as well.
        • Dave S.
          • August 31, 1992
          • 2918
          Thanks Patrick,
            • 11608
            Dave,
            First one was a joke. That's why the smileys....
            The only FP I find on a Google search is a 3.73 posi in a 1967 Nova or Chevelle. The only time I can find that casting number is for a Corvette. As you've noted, I don't see a 3789812 and an FP together anywhere.
            You're sure it's FP? 1962 (per my books) ther are no F_'s for Corvette.
            Patrick
              • 11608
              Dave,
              Patrick
              • Dave S.
                • August 31, 1992
                • 2918
                Re: Rear Center section ID help/Still needed *NM*
                • Dave S.
                  • August 31, 1992
                  • 2918
                  • Tom D.
                    • September 30, 1981
                    • 2126
                    Patrick: Imagine what your started!
                    Could it be the F= Ford, a four letter F-word?
                    https://MichiganNCRS.org
                    Michigan Chapter
                    Tom Dingman
                    • Tom D.
                      • 2126
                      Michigan Chapter
                      Tom Dingman
                        • 11608
                        Re: Patrick: Imagine what your started!
                        No, there are F_ differential codes on other year solid axle Corvettes, but not 1962. In fact, they go through FM in other years, but no FP. That's why I asked Dave if he's sure about the code. With a differential casting that's "supposed" to be Corvette only, but a code that doesn't make sense, I'd re-examine the code.
                        Just my own thoughts.
                        Patrick
                          • 11608
                          Patrick
                          • Dick W.
                            • 10483
                            Passenger car??
                            Dick Whittington
                            • Dick W.
                              • 10483
                              Passenger car??
                              Dick Whittington
