i was putting the half shafts back in my 69 tonight after pressing in new u-joints and im having a binding problem. the rear end yokes bind when the shaft loop passes it at the bottom. i have the weight of the car on the strut rods. i took them back off and radiused the edges but one side is still binding. i can see where it wore groves in the shaft loop. i put it on with that side on the trailing arm side thinking they were symetrical. ie no right or left side and no inner or outer ends. what am i doing wrong or is this a common problem that "wears" its self in as you drive it?
regards dick
regards dick
