461 heads flow numbers - Duke et. al. - NCRS Discussion Boards
  • Clem Z.
    • January 1, 2006
    • 9427
    do the valves have a back angle cut?
    this will help low lift flow. a change to 30 degree intake seat will also help low lift flow
    • Clem Z.
      • January 1, 2006
      • 9427
      • Don C.
        • November 1, 2003
        • 34
        #18
        Re: do the valves have a back angle cut?
        Clem
        They do NOT have the back angle cut yet. I will do that before I take the heads back for a flow test following my attempt to pocket port one of the cylinders. At this point only one cylinder has been done by the machinist. I will do the rest of the cylinders. I was planning to do the back cut on only the intake valve a to do a radius on the combustion chamber side of the exhaust valve. Does this fit with your thinking?
        Don
        • Don C.
          • November 1, 2003
          • 34
          #19
          Clem
          Don
          • Don C.
            • November 1, 2003
            • 34
            #20
            Re: the ID of the intake port at the valve should
            Bryan
            Thanks for sharing.
            Don
            • Don C.
              • November 1, 2003
              • 34
              #21
              Bryan
              Thanks for sharing.
              Don
              • Clem Z.
                • January 1, 2006
                • 9427
                #22
                back cut both valves. did you get my pictures and flow sheets is sent?
                • Clem Z.
                  • January 1, 2006
                  • 9427
                  #23
                  • Don C.
                    • November 1, 2003
                    • 34
                    #24
                    Got 'em and studying them.
                    Many thanks
                    Don
